[Qgis-user] GML2/GML3 encoding in WPS input (WPS plugin 0.6.16)
Horst Düster horst.duester at kappasys.ch
Fri Feb 10 01:32:41 PST 2012
Im not sure what happend in your case. But the Plugin doesnt manipulate
incoming data. It only downloads the resultand features from the server
as it is and integrates them into QGIS.
Regards
Horst
Dr. Horst Düster
Kappasys
Alte Bernstrasse 13
CH-4500 Solothurn
Tel.: +41 (0) 32 514 00 40
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Twitter: moazagotl
Web: www.kappasys.ch
lat: N 47° 12' 06.408" lon: E 7° 32' 13.740"
Am 10.02.2012 07:25, schrieb Augusttown:
> Hi folks,
> I am using the QGIS WPS plugin to consume one WPS process. One of the input
> parameter type is defined as below in process description:
> <ComplexData>
>      <Default>
>          <Format>
> 	<MimeType>text/xml</MimeType>
> 	<Encoding>UTF-8</Encoding>
> 	<Schema>http://schemas.opengis.net/gml/3.1.1/base/gml.xsd</Schema>
> 	</Format>
>      </Default>
> </ComplexData>
> So I selected one feature from a shapefile layer as input and execute the
> process, and in the Execute request WPS plugin sends I captured following
> GML as complexData
> <gml:featureMember>
>      <ogr:qt_temp fid="F1">
>      <ogr:geometryProperty>
>          <gml:Point>
> <gml:coordinates>-13629600.1153,4547314.1181999967</gml:coordinates>
>          </gml:Point>
>      </ogr:geometryProperty>
>      </ogr:qt_temp>
> </gml:featureMember>
> Obviously the input feature is encoded as GML2, so I wonder why the input
> feature is encoded as GML2 instead of GML3? Is it a limitation of QGIS/WPS
> plugin or did I miss anything.
> I do notice that WPS plugin can successfully parse GML3 for some other
> process that output GML3, so how I can configure it to make WPS client
> encode input features as GML3?
> Thanks
> View this message in context: http://osgeo-org.1560.n6.nabble.com/GML2-GML3-encoding-in-WPS-input-WPS-plugin-0-6-16-tp4382424p4382424.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
