FW: [Qgis-user] Google Earth
Alister Hood Alister.Hood at synergine.com
Sun Feb 12 13:10:54 PST 2012
Copying to the list...
> From: Chuck Young [mailto:wylie1066 at gmail.com]
> Sent: Monday, 13 February 2012 5:52 a.m.
> To: Alister Hood
> Subject: Re: [Qgis-user] Google Earth
> I had that set to on the fly but the layers would load and show so far off the range that when you go to extents the Google satellite layer would finally display up to eight copies of the continents. and my little smudge was so small that I could never locate it.   I finally decided to just recreate the layers I need as they only require a couple of days to get in.  It is a lot of work but less than fighting the projection then doing it.   I tried both re-projection and on the fly. I tried setting the project CRS to Google Mercator and different settings and anything else I could think of.
> I would have thought that because the Tiger roads layer worked the water layer would, but no.  So I will go ahead without that layer for now.
> Thanks for your help and efforts.  I really appreciate your kindness. If you think of anything else I could try I would like to hear.
> Thanks again!
> Chuck
> > On Sun, Feb 12, 2012 at 2:35 AM, Alister Hood <Alister.Hood at synergine.com> wrote:
> > Are you sure you need to translate them?
> > You can't just use on-the-fly reprojection?
