[Qgis-user] Displaying single band GRASS raster
Werner Macho werner.macho at gmail.com
Mon Feb 13 11:54:33 PST 2012
Hi Giovanni,
So no commit number or message to search for? That makes it a bit hard
to identify ..
And if there is a bug that is still not solved in master - there is
nothing to backport..
kind regards
Werner
Am 13.02.2012 20:47, schrieb Giovanni Manghi:
> Hi Werner,
> until 1.7.3 (included) there are a few bugs that make not possible to
> work with the GRASS plugin. Those bugs were solved from 11/09/11 on,
> some were fixed upstream, others by Radim, Jurgen, Giuseppe. You can
> check in Redmine.
> Actually in master a new blocking bug has surfaced that still need to be
> solved
> http://hub.qgis.org/issues/4862
> cheers
