[Qgis-user] Problem in FTools 0.6.1 union
Giovanni Manghi giovanni.manghi at faunalia.pt
Tue Feb 14 06:07:17 PST 2012
This should have been fixed in qgis master
http://hub.qgis.org/issues/4567
can you give it a try?
thanks
-- Giovanni --
On Tue, 2012-02-14 at 06:01 -0800, bertGIS wrote:
> Hi.
> It seems that the Union tool furnished with QGIS Wroclaw and Ftools 0.6.1
> does not manage the union attributes correctly.
> Tested with one "A" layer with an "ID" attribute with value 125, one "B"
> layer with an "ID" attribute with value 200 and the two layers (simple
> vector layers with only one feature for each one) overlapping on one part.
> You make the union.
> After that, you have a resulting layer with 2 fields : ID and ID_2
> The attribute table is the following:
>      ID            ID_2
> 0   125          200             (the overlapping region)
> 1   125          NULL           (the "A only" region)
> 2   125          NULL           (the "B only" region)
> Should'nt the feature number 2 attributes be ('2', NULL, '200').
> It seems 0.5.10 Ftools version did not contain this problem.
> Cheers,
> Bert
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-in-FTools-0-6-1-union-tp4468927p4468927.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
