[Qgis-user] QGIS Portable (USB)
Richard Duivenvoorde rdmailings at duif.net
Wed Feb 15 01:15:35 PST 2012
On 02/15/2012 09:29 AM, Stephane BELIN wrote:
> Hello,
> I've reading qgis1.7.0 user guide, but I'dont find where is the commande
> line.
> Can you explain me or make a screenshoot please?
Please have a look at par 3.1.1 of the doc Alexander points to.
It's about starting qgis not by double clicking on the icon, but by
typing something like (if your usb is on h:) (thinking you are on windows)
qgis.exe --configpath [your config path]
So if you installed qgis on the usb which is in H: disk, then go to the
qgis.exe on H: disk in a terminal command box (dos box on windows?): and
type
H:\[path to qgis.exe]\qgis.exe --configpath H:\qgisconfig
In this way qgis will start up and put all plugins and configuration in
that folder instead of your home folder
Faunalia also provided usbgis images:
http://www.faunalia.pt/usbgis#seis
not sure if they still do.
Regards,
ps somebody volunteering to show this on Windows with some screenshots
and blog about it?
