[Qgis-user] Re: QGIS WPS Plugin 0.75 fails to execute while 0.6.16 worked
Augusttown anakintang at gmail.com
Wed Feb 15 06:52:50 PST 2012
Hi Horst,
Thanks for the response. So far I can't really tell what exactly was wrong
because I was able to capture POST <Execute> request sent by the plugin ,
which looks fine. But the same WPS server just wasn't able to see the xml
body of the POST request. So that was why I asked for 0.6.16 to figure out
what has been changed in the request.
Is there a way to downgrade to 0.6.16?
Thanks,
Yingqi
On Wed, Feb 15, 2012 at 4:39 AM, Horst Düster [via OSGeo.org] <
ml-node+s1560n4471951h93 at n6.nabble.com> wrote:
> The plugin has changed in the way that it uses the QgsNetworkAccessManager
> to connect to the Internet instead of QHttp. Please send the error message
> and the version of QT.
> Regards
> Horst
> Augusttown <[hidden email]<http://user/SendEmail.jtp?type=node&node=4471951&i=0>>
> schrieb:
> >Hi all,
> >I was using QGIS WPS plugin 0.6.16 for the past a few months against one
> >particular WPS process, and everything seems to be fine. But today I
> upgrade
> >to WPS client 0.75 and the Execute starts to fail on every process.
> >I captured the <Execute> POST request and the xml part seems to be the
> same.
> >So my question is whether there is any change in the way the plugin sends
> >out the POST request (content-type etc.?).
> >BTW, is there a way I switch back to QGIS WPS plugin 0.6.16 somehow?
> >Thanks
> >View this message in context:
> http://osgeo-org.1560.n6.nabble.com/QGIS-WPS-Plugin-0-75-fails-to-execute-while-0-6-16-worked-tp4470622p4470622.html
> >Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> >_______________________________________________
> >Qgis-user mailing list
> >[hidden email] <http://user/SendEmail.jtp?type=node&node=4471951&i=1>
> >http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4471951&i=2>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/QGIS-WPS-Plugin-0-75-fails-to-execute-while-0-6-16-worked-tp4470622p4471951.html
>  To unsubscribe from QGIS WPS Plugin 0.75 fails to execute while 0.6.16
> worked, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4470622&code=YW5ha2ludGFuZ0BnbWFpbC5jb218NDQ3MDYyMnwtMjY2NTI4OTUx>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-WPS-Plugin-0-75-fails-to-execute-while-0-6-16-worked-tp4470622p4472440.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120215/baed8481/attachment.html>
