[Qgis-user] .Net Control and more
Alister Hood Alister.Hood at synergine.com
Mon Feb 27 13:29:17 PST 2012
> Date: Mon, 27 Feb 2012 09:41:29 -0800
> From: Alex Mandel <tech_dev at wildintellect.com>
> Subject: Re: [Qgis-user] .Net Control and more
> To: qgis-user at lists.osgeo.org
> Message-ID: <4F4BC049.9000805 at wildintellect.com>
> Content-Type: text/plain; charset=ISO-8859-1
> On 02/27/2012 09:10 AM, David Speyer wrote:
> > Thanks for getting back to me Alister!
> > Now I have more specific questions for the group:
> > 1)	What map formats are supported?  In particular are TAB files supported?
> Anything supported by GDAL/OGR, www.gdal.org
Note that in the case of vector TAB files, support is for reading and also writing of new layers.  Editing of an existing TAB is not currently possible.
> > 2)	Can QGIS be used as a Control - Is there an existing tool that can easily be wrapped into a .Net C# Windows Control?   (The equivalent of MapInfo Extreme).
> Yes, but only C++ and python
> > 3)	Can a floor plan jpg file be layered over a blank map control and then registered via TAB file using minimally three points on the map with Latitude and Longitude?  Then with mouse click know all the other coordinates on the map?   Is this a simple process?  (Again this can be easily done with MapInfo Extreme).
> Yes, georegistration tool is built in.
Note that registration is not _via a TAB file_.  QGIS only supports TAB files that actually contain vector data, not the TAB files that MapInfo uses to refer to any non-TAB data (vector or raster).
Registration is either by creating a new file which contains the georeferencing information (this would need to be a geotiff or something which supports that), or via an ESRI style "world file" (these often have extensions like .wld .jgw .tfw etc).  I seem to remember that MapInfo is too useless to understand world files, but I could be wrong (maybe it was too useless to understand the built-in georeferencing in ecw files or something?).
Both world files and the georeferencing TAB files are plain text, so you can create one from the other if necessary.
> > 4)	Web App and Stand Alone Support?
> There is work on Web Client to correspond with QGIS Server. Desktop standalone is the primary mechanism for all current deployments.
I think there are _2_ web clients now :)
> > 5)	Has Layering - Ability to draw several layers of routes and various symbols with different colors onto to the displayed map - programmatically controlled?  Legend? (Again using as .Net Control).
> Yes, but again only C++ and python
> > 6)	Access to Maps (can you get from web database?)
> Yes, WMS, WFS, Tiles, Postgis, etc.. are all supported.
> > 7)	Report Generation Capabilities:  If we were to wrap QGIS, is there a wide variety of reports that can be generated (i.e. letting the end user create custom map-based reports)?
> Only a few such plugins exist but could be easy to write.
> I think you are more likely to want to look at SharpMap and MapWindow which are .net applications and tools under open source licenses.
