[Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue Feb 28 04:25:43 PST 2012
Hi Brent,
I am trying to reproduce this issue without results at the moment.
Looking more into this.
Regards,
Angelos
On 02/27/2012 11:03 PM, pcreso at pcreso.com wrote:
> Hi Angelos,
> I just installed QGIS 1.74 (from 1.73 which worked fine) on OpenSuse
> 12.1 64bit.
> It is now broken with a startup error message as below.
> My libpython was 2.7 from the standard repository. This had the same
> version as the python repo you suggested.
> QGIS is running, but with no python support, my system is fully
> updated as far as I can tell.
> Any advice/fixes appreciated...
> Thanks,
>   Brent
> Error msg below
> _____________________________________________________________
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
>    File "", line 1, in
> ImportError: /usr/share/qgis/python/qgis/core.so: undefined symbol: _ZNK7QObject17senderSignalIndexEv
> Python version:
> 2.7.2 (default, Aug 19 2011, 20:41:43) [GCC]
> QGIS version:
> 1.7.4-Wroclaw 'Wroclaw', exported
> ________________________________________________________________
> --- On *Tue, 2/28/12, Angelos Tzotsos /<gcpp.kalxas at gmail.com>/* wrote:
>     From: Angelos Tzotsos <gcpp.kalxas at gmail.com>
>     Subject: Re: [Qgis-user] Re: QGIS 1.7.4 doesn't run in OpenSUSE 12.1
>     To: qgis-user at lists.osgeo.org
>     Date: Tuesday, February 28, 2012, 6:47 AM
>     Hi,
>     QGIS 1.7.4 works fine in my machines
>     You should add this repository in your system:
>     http://download.opensuse.org/repositories/devel:/languages:/python/openSUSE_12.1/
>     update and try installing qgis again
>     Regards,
>     Angelos
>     On 02/27/2012 06:24 PM, Donovan Cameron wrote:
>>     I noticed my error when QGIS upgraded to 1.7.3 as well, but never
>>     got around to reporting it, then 1.7.4 came out soon afterwards.
>>     It opened and ran fine in v 1.7.2
>>     I will check my python version when I get home tonight and see if
>>     that could be it if not, I may rollback to 1.7.2.
>>     I'll follow your forum thread for updates as well.
>>     Donovan
>>     On Mon, Feb 27, 2012 at 8:24 AM, Kerick Leite
>>     <kerick.quimica at gmail.com
>>     </mc/compose?to=kerick.quimica at gmail.com>> wrote:
>>         I had a problem with the installation of QGIS 1.7.3 in the
>>         same version of OpenSUSE as yours. The problem was caused by
>>         a missing dependency also related to python. I've posted the
>>         problem in the forum, but so far there wasn't a reply:
>>         http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6
>>         <http://forum.qgis.org/viewtopic.php?f=3&t=10012&sid=76d8f641ce6c9e16198adf6ef41b52e6>
>>         Regards,
>>         Kerick
>>             Message: 6
>>             Date: Sun, 26 Feb 2012 16:38:10 -0700
>>             From: Donovan Cameron <sault.don at gmail.com
>>             </mc/compose?to=sault.don at gmail.com>>
>>             Subject: [Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
>>             </mc/compose?to=qgis-user at lists.osgeo.org>
>>             Message-ID:
>>             <CAJo0jfPr+K5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com
>>             </mc/compose?to=CAJo0jfPr%2BK5GzWTLH4uTgE3VKT8QCO6XJXnP88YKmNjKBe3Rvw at mail.gmail.com>>
>>             Content-Type: text/plain; charset="iso-8859-1"
>>             When I try to run qgis from the terminal, the splash
>>             shows, but as soon as
>>             it gets to the part "Starting Python" the splash simply
>>             closes.
>>             The output from the terminal is:
>>             *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
>>             `(((currentType)->td_flags & 0x0007) == 0x0003)' failed.*
>>             *Aborted*
>>             I downloaded and installed QGIS from the "geo" repository (
>>             http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
>>             QGIS: 1.7.4-Wroclaw
>>             OS: OpenSUSE 12.1 with KDE 4.8
>>             Kernel: 3.1.9-1.4-desktop
>>             Regards,
>>             Donovan
>>             -------------- next part --------------
>>             An HTML attachment was scrubbed...
>>             URL:
>>             http://lists.osgeo.org/pipermail/qgis-user/attachments/20120226/8bedc4f5/attachment-0001.html
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org
>>         </mc/compose?to=Qgis-user at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Qgis-user at lists.osgeo.org  </mc/compose?to=Qgis-user at lists.osgeo.org>
>     Angelos Tzotsos
>     Remote Sensing Laboratory
>     National Technical University of Athens
>     http://users.ntua.gr/tzotsos
>     -----Inline Attachment Follows-----
Angelos Tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120228/0e4d9b84/attachment.html>
