[Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Feb 29 02:03:28 PST 2012
Yes, this is the best solution if you have upgraded KDE to 4.8
Angelos
On 02/29/2012 11:45 AM, Sebastian Schubert wrote:
> On 27/02/12 21:42, Sascha Eichenauer wrote:
>> On 02/27/2012 09:38 AM, Donovan Cameron wrote:
>>> When I try to run qgis from the terminal, the splash shows, but as soon as
>>> it gets to the part "Starting Python" the splash simply closes.
>>> The output from the terminal is:
>>> *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
>>> `(((currentType)->td_flags&  0x0007) == 0x0003)' failed.*
>>> *Aborted*
>>> I downloaded and installed QGIS from the "geo" repository (
>>> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
>>> QGIS: 1.7.4-Wroclaw
>>> OS: OpenSUSE 12.1 with KDE 4.8
>>> Kernel: 3.1.9-1.4-desktop
>> the QGIS in the GEO: repository is built against Qt 4.7 which ships with
>> KDE 4.7. KDE 4.8 comes with Qt 4.8. You either have to build QGIS from
>> source or downgrade to KDE 4.7. That's why I did not upgrade to KDE 4.8...
> I use KDE 4.8. I downloaded the srpm and built it myself. Fairly
> straightforward. I had to install some additional dependencies for
> building and had to comment some lines in the spec file about debugging
> information (I guess the spec wants me to generate debugging symbols but
> I don't know how and I was to lazy to investigate).
> Sebastian
> Qgis-user mailing list
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120229/a0cce402/attachment.html>
