[Qgis-user] Re: [Qgis-developer] Offset curve tool
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Feb 29 05:45:20 PST 2012
Hi Denis
In certain cases, geos trunk throws an exception (version 3.2 crashes):
ERROR 1: IllegalArgumentException: RobustDeterminant encountered
non-finite numbers
I noticed it happens often with lines with dense vertex distributions
(e.g. segmented curves). Maybe Sandro (strk) knows more about the details?
Regards,
Marco
On 29.02.2012 14:28, Denis Rouzaud wrote:
> Hi Marco,
> I noticed a bug and Qgis crashes.
> Here is a video http://youtu.be/DBbMg5rO8fU
> The geometry of the line I played with is:
> LINESTRING(554235.01669295 145547.73137862,554242.99020772
> 145548.76938867,554245.33776182 145545.30016923,554245.49416371
> 145544.76210759)
> Greetings,
> Denis
> On 02/29/2012 11:11 AM, Marco Hugentobler wrote: Hi all
> There is a new editing tool in the master branch.
> The offset curve tool creates parallel shifts of linestrings and
> polygon rings ( single sided buffers with the geos function
> GEOSSingleSidedBuffer ). The tool can be applied to the edited layer
> (the geometries are modified) or also to background layers (creates
> copies of the lines / rings and adds it to the the edited layer). It
> is thus ideally suited for the creation of distance line layers.
> Let me know about issues, suggestions, comments.
> The work was kindly funded by the city of Uster (Switzerland).
> Regards,
> Marco
>> Hi all
>> Regards,
>> Marco
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
