[Qgis-user] Re: pre-formatting KML output in QGIS or other options
Bill Teluk
Bill.Teluk at team.telstra.com
Fri Jan 13 03:18:33 PST 2012
No worries Maning!
maning sambale wrote
> I still need to learn how to add a
> <description> tag in the output KML that include htl formatted text
> based on the input KML's extended data.
I think you can output arbitrary tags either by including them directly in
amongst the XSL, or by using the xsl:element tag eg.
If you're going to include HTML, it might be just simpler to write it all
just as straight text rather than code it as xsl:element, xsl:attribute
tags.
There's some good tutorials at http://www.w3schools.com/xsl/ with examples
that are particularly useful if you're looking to code a bunch of repetitive
items - such as lines, point objects etc.
I've recently been hacking around at converting GML3 to GML2 compliant
structures and I found the xsl:templates to be very useful for picking up
repeating items. Also, the "identity" function (
http://www.dpawson.co.uk/xsl/sect2/identity.html ) can be useful for passing
through content that you don't want to modify - your template just picks up
the bits you do want to edit, and the rest goes through without alteration.
Regards, Bill.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/pre-formatting-KML-output-in-QGIS-or-other-options-tp7166321p7183711.html
Sent from the qgis-user mailing list archive at Nabble.com.
