[Qgis-user] Atlas plugin - create map books
Luca Lanteri mescal72 at gmail.com
Tue Jan 31 06:52:36 PST 2012
Hi, I'm trying to use the atlas plugin.
All works fine except that if I use my local projection system (EPSG:
32632) the WMS base map
is printed shifted. If I print directly via QGIS composer the WMS is
printed in the right way.
The same thing happened with the map book plugin but it can be solved using
the trick of "print as raster".
Anyone can confirm to me this bug. Can I do some other test that can be
used to solve the problem ?
thanks
Luca
2012/1/31 Vincent Picavet <vincent.ml at oslandia.com>
> Hi,
> > This is a very useful idea, but seems to be not working on my OSX
> > environment using a trunk build. I submitted a couple of bugs that you
> may
> > already have seen. For convenience, I've linked them here as well.
> Perhaps
> > others who have developed python plugins will be able to assist in
> > debugging these issues.
> > http://hub.qgis.org/issues/4922
> > http://hub.qgis.org/issues/4923
> Thanks for using the tracker for bug reporting.
> I don't have any OSX platform to test on, so if other have the same issues
> on
> windows/linux, please report too, otherwise we'll probably have to wait for
> someone to check the issue on OSX.
> > Thanks for undertaking this quality addition for qgis. I look forward to
> > seeing it progress.
> It will :)
> Vincent
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120131/4b9bb2a6/attachment.html>
