[Qgis-user] New Labeling: conditional labels
Nathan Woodrow
madmanwoo at gmail.com
Fri Jan 6 20:09:54 EST 2012
Love your work Martin!
I'll add syntax highlighting for it tonight/tomorrow sometime.
- Nathan
On Sat, Jan 7, 2012 at 10:31 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Fri, Jan 6, 2012 at 1:25 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> > SQL recognizes CASE statement with following alternate syntax:
> > 1. "if" equivalent:
> > CASE
> > WHEN x > 10 THEN 'big' ELSE 'small'
> > END
> Just pushed a commit implementing that.
> The syntax is:
> CASE WHEN cond1 THEN exp1 [WHEN cond2 THEN exp2]* [ELSE exp3] END
> There may be one or more WHEN/THEN clauses. If no condition matches,
> the expression from "ELSE" is evaluated - if none is specified then
> NULL is returned.
> Note: the other syntax with "base" expression (CASE x WHEN y THEN z
> ... END) is not supported yet.
> Have fun!
> Martin
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120107/4d9af130/attachment.html
