[Qgis-user] Ubuntu 12.04 And Qgis 1.8 - Broken Depencies
nikos ves vesnikos at gmail.com
Tue Jul 10 05:06:57 PDT 2012
I'm forwarding this from [1] so if anyone can help and the enquirer
Has anyone had any luck with getting QGIS working on Ubuntu 12.04? I
have tried the stable and unstable versions and with not luck. I also
get the following:
"Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qgis : Depends: qgis-providers (= 1.8.0-1~precise1) but 1.9.90
+git20120502+6229eec~precise1 is to be installed
    Depends: qgis-common (= 1.8.0-1~precise1) but 1.9.90+git20120502
    Recommends: qgis-plugin-globe but it is not going to be installed
    Recommends: qgis-plugin-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages."
[1]http://gis.stackexchange.com/questions/29094/how-to-install-qgis-on-ubuntu-12-04/
