[Qgis-user] Problems to install QGIS 1.8 on Windows XP
Tim Sutton lists at linfiniti.com
Tue Jul 10 14:31:20 PDT 2012
Hi
2012/7/10 José Carlos Guerrero Antúnez <jcgantunez at gmail.com>:
> Hi,
> I want to install Qgis 1.8 on a pc Windows XP and I have this message error
> "Not Found The procedure entry point TIFFMergeFieldInfo in the dynamic link
> library libtiff.dll"
Probably you have another libtif.dll on your system that is
conflicting with QGIS. Try searching your windows dir for libtiff.dll
and if present temporarily rename it then restart QGIS. If it works
you will need to figure out a more permanent solution to do without
that dll.
Regards
Tim
> Regards,
> José C. Guerrero
> Dr. José Carlos Guerrero
> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> (LDSGAT)
> Instituto de Ecología y Ciencias Ambientales (IECA)
> Facultad de Ciencias
> Universidad de la República
> Montevideo-URUGUAY
> Qgis-user mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
