[Qgis-user] Smooth DEMs
richard burcher drownedfrog at gmail.com
Wed Jul 11 05:41:18 PDT 2012
Hi Clemens,
To smooth dems, use the following:
Install  http://www.saga-gis.org/en/index.html saga gis  & install the
sextante plugin. Under the Analysis menu, open the Sextante options &
configuration, click on saga. Sextante should find your install of saga (I'm
assuming a windows platform here) at something like c:/program
files/saga-gis/. Ensure the "use min covering grid system for resampling" is
checked.
Click Analysis menu -- Sextante Toolbar. This opens the toolbox, you can
type filter in the text search. Alternatively, just expand saga -- grid
filter, you will have ~ 10 filter choices. Not sure of the filtering
application (cartographic or analytical) you can employ the "simple" filter
with its default smooth using 11*11 for ~ 990m output. If maintaining slopes
are important, review the multi-directional filter as it implements a lee
based filter.
I'm pretty sure the input raster must be tif.
Moving the srtm 90m? to 1km resolution is resampling the dataset. You can
use the built in gdal tools--  http://www.gdal.org/gdalwarp.html warp
dialog for this. In the dialog after you have entered the information click
the pencil to allow editing of the config text, add the following argument
(before the -r method) to allow resample to 1km -tr 1000 1000. Ensure
resample method is not near but bicubic.
You can empose spatial scale on your orginial srtm90m by filtering with a
large filter say 11*11 (~990m support area) but the dem posting will remain
90m. This avoids resampling & may be a better way forward, I've used the
aforementioned approach for some soil tools.
Cheers,
Richard
View this message in context: http://osgeo-org.1560.n6.nabble.com/Smooth-DEMs-tp4987519p4987640.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
