[Qgis-user] Qgis 1.8 : How to do an Unilateral buffer
Murkor mharte at ozemail.com.au
Wed Jul 11 07:31:01 PDT 2012
"I'm working on Cameroon coastal layer shapefile and i would like generate
several unilateral buffers : buffers only on one side (toward ocean) and no
toward continent."
laurent,
If you create your buffer of the continental edge then erase (use the
"difference" geoprocessing function) the continental side with the continent
feature you'll get a unilateral buffer.  Use the buffer as the "input vector
layer" and the continental feature as the "difference layer.  This process
assumes the continent data set has a polygon geometry.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Qgis-1-8-How-to-do-an-Unilateral-buffer-tp4987586p4987690.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
