[Qgis-user] contours
john raskulinecz jerasku at hotmail.com
Wed Jul 11 12:55:56 PDT 2012
Micha,     Believe it or not since I last posted and before I rechecked the list I did just that. It works wonderfuly! The file I am contouring contains magneric readings and plays well with other layers once the crs's are set. I have some gravity data that is in the same txt format however that does not. Do you think that if I first convert to ersi shp file it will contour? Any way I'll try that now.Thanks once more,J.R.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120711/b444d991/attachment.html>
