[Qgis-user] plugin help
Richard Duivenvoorde rdmailings at duif.net
Thu Jul 12 05:41:48 PDT 2012
ok, this is more clear :-)
You can toggle editing mode of a vector layer via the little crayon
button or via menu layer/toggle editing
but looking into the code, which I downloaded from
http://pyqgis.org/repo/contributed/
it seems to me that after every transformation, the result is 'commited'
which toggles OFF again the edit mode...
If you feel brave, uncomment line 118 in qgsAffine.py:
     # vlayer.commitChanges()
But maybe Mauricio can update the code for us, and also move his plugin
to the new repositiry :-)
Regards,
Richard
ps I will send you my .py file offline
On 07/12/2012 12:25 PM, chathura silva wrote:
> I try to edit a vector layer using qgisaffine tool. But it says layer is
> not in editabale mode. how can I cange it to editable mode
> On Thu, Jul 12, 2012 at 1:27 AM, Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>     On 07/12/2012 09:16 AM, chathura silva wrote:
>         Is there any way to change it to editable mode ?
>     Please describe your problem a little more instead of one sentence
>     questions, for others it also costs time to answer your question.
>     If you mean 'is it possible for a python plugin to set a layer in
>     the modus editing' the answer is:
>     yes
>     but I think you also would like to see some pointers (after you
>     tried to google a little ;-) ):
>     Have a look here:
>     http://qgis.org/pyqgis-__cookbook/vector.html#__modifying-vector-layers
>     <http://qgis.org/pyqgis-cookbook/vector.html#modifying-vector-layers>
>     I'm also setting a layer into editing mode, see
>     http://hub.qgis.org/projects/__xytools/repository/revisions/__a249004832f44334f9861483ff9d4d__a08bb91e81/entry/xytools.py
>     <http://hub.qgis.org/projects/xytools/repository/revisions/a249004832f44334f9861483ff9d4da08bb91e81/entry/xytools.py>
>     at line 334
>     Regards,
>     _________________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/__mailman/listinfo/qgis-user
>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
