[Qgis-user] CRS being read differently by 1.8 on different OS
Ramon AndiƱach custard at westnet.com.au
Thu Jul 12 07:47:46 PDT 2012
Hmm ok. I don't think I'm able to, unfortunately.
However, it probably isn't needed. I've just re-opened everything and everything behaved as expected.
So my current best thought is that I did something differently in at work this morning and in my current flu and bike related brain stupor forgot what that I'd done it.
Apologies for the racket.
-ramon.
On 12/07/2012, at 19:57 , Etienne Tourigny wrote:
> The difference is *probably* due to differences in gdal and/or PROJ.4
> versions in the two environments.
> You can check that out with running 'gdalinfo <file>' or 'gdalsrsinfo
> <file>' on both enviromnents.
> Could you post a link to the file (ideally a subset of it)?
> Shapefile CRS recognition has suffered from many problems in the past
> (which should be fixed in 1.8), but I haven't seen this kind of
> problem with raster data.
> Etienne
> On Thu, Jul 12, 2012 at 2:19 AM, Ramon AndiƱach <custard at westnet.com.au> wrote:
>> Hi,
>> I realise that this probably isn't strictly a QGIS problem, but I've noticed something odd about a raster file that I've been handed to look at.
>> On MacOS (using William's 1.8 build), the file and its associated meta files is reporting as a custom CRS (+proj=longlat +a=6378249.145 +b=6356514.966395495 +no_defs)
>> On Win7-64bit (using OSGeo), the same file and associated meta files is reporting as Cape EPSG:4222.
>> This seems a little odd, and I wondered if anyone had any thoughts.
>> -ramon.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
