[Qgis-user] Problems with profile from line altitude values + r.water.outlet command
Jaime Palalane mitasjp at gmail.com
Fri Jul 13 08:10:01 PDT 2012
Thank you for this prompt reply. One additional question. Is there any
quick way to get a hipsometric curve or area values between different
altitude intervals from a DEM representing my basin?
Jaime
2012/7/13 Micha Silver <micha at arava.co.il>
>  On 07/13/2012 04:02 PM, Jaime Palalane wrote:
> Dear qgis users,
> I am trying to use qGIS to characterize a hydrographic basin but I am
> facing problems with the profile from line tool as it is giving an unique
> altitude value for my rivers and lengths in grades. I would like to have
> them in SI units. I would appreciate some tips in how to solve this problem.
> The units should be the units of the coordinate system. I think that if
> you want altitudes and lengths in meters, you'll have to project both the
> raster and the line features to a projected CRS with meters as units.
> I am also trying to use the r.water.outlet command to define a basin
> draining to a specific point of a stream in raster format but without
> success as it gives me back only one cell as the basin and not a
> combination of cells which could form a real basin. Any tutorial or video
> in how to use this command?
> Perhaps the problem is that the outlet point must fall exactly on a
> stream.  There's a trick using v.distance to find a drainage point exactly
> on the stream, described here:
> http://www.surfaces.co.il/?p=241
> First add two columns to the streams layer: outlet_x, outlet_y. Now use
> v.distance with your outlet point as the "from" parameter, and the stream
> as the "to" parameter. Set the upload parameter to "to_x,to_y" and the
> column parameter to "outlet_x,outlet_y". Now after you run, you should get
> the X,Y coordinates of a point *on the stream* nearest to your planned
> outlet point. Use those coordinates in your r.water.outlet command, and you
> should get the full drainage area.
> HTH,
> Micha
> SaudaƧoes!
> Jaime
> This mail was received via Mail-SeCure System.
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
> Micha Silver
> GIS Consultant, Arava Development Co.http://www.surfaces.co.il
Jaime Palalane
+258 82 70 56 990
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120713/968af76a/attachment.html>
