[Qgis-user] Atlas Plugin
lt bisnulama at hotmail.com
Fri Jul 13 10:39:21 PDT 2012
what should I search for?
I write ATLAS in the search bar but in no repository I find the atlas plug in. I am running Qgis 1.7.3 under winXP
can you paste me the repository's address to add it manually?
thank you
laura
Il giorno 13/lug/2012, alle ore 19:23, Vincent Picavet ha scritto:
> Hi,
> Le vendredi 13 juillet 2012 19:12:36, lt a écrit :
>> I read in this ML about the Atlas Plugin, but I cannot find it in the fetch
>> python plug in console. Can you help me? thank you
> There are now 2 versions, both in the new repository :
> * stable needs at least qgis 1.6
> * experimental needs at least qgis 1.9 (current master)
> If you still run qgis < 1.8 you have to add the new repository manually, but
> you'd better install ggis 1.8 and have it out of the box.
> Vincent
