[Qgis-user] Can't open a project in Qgis 1.8 (OSX)
William Kyngesburye woklist at kyngchaos.com
Fri Jul 13 12:08:15 PDT 2012
What happens when you open it?  Crash or nothing?
Did you move or delete a layer source outside of QGIS?  Specifically a CSV file.
On Jul 13, 2012, at 1:25 PM, José Carlos Guerrero Antúnez wrote:
> Hi,
> I created a project in Qgis 1.8 (OSX 10.6.8), it was saved correctly, opened many times but today I can't open it. It's very important for me because I spent much time working on it.
> On the contrary, I could open a project created in an earlier version.
> Console message,
> 13/07/12 15:20:08	[0x0-0x51051].org.qgis.qgis[705]	Warning: loading of qgis translation failed [/Applications/QGIS.app/Contents/MacOS/../Resources/i18n//qgis_en_US]
> 13/07/12 15:20:08	[0x0-0x51051].org.qgis.qgis[705]	Warning: loading of qt translation failed [/Applications/QGIS.app/Contents/translations/qt_en_US]
> 13/07/12 15:20:09	[0x0-0x51051].org.qgis.qgis[705]	ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'.
> 13/07/12 15:20:11	[0x0-0x51051].org.qgis.qgis[705]	/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.6/site-packages/osgeo/gdal.py:80: DeprecationWarning: gdal.py was placed in a namespace, it is now available as osgeo.gdal
> 13/07/12 15:20:11	[0x0-0x51051].org.qgis.qgis[705]	  DeprecationWarning)
> 13/07/12 15:20:15	[0x0-0x51051].org.qgis.qgis[705]	/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py:309: DeprecationWarning: the sets module is deprecated
> 13/07/12 15:20:15	[0x0-0x51051].org.qgis.qgis[705]	  mod = _builtin_import(name, globals, locals, fromlist, level)
> 13/07/12 15:20:15	[0x0-0x51051].org.qgis.qgis[705]	/Users/joseca_IMac/.qgis//python/plugins/openlayers/openlayers_plugin.py:211: DeprecationWarning: QgsCoordinateReferenceSystem.createFromEpsg() is deprecated
> 13/07/12 15:20:15	[0x0-0x51051].org.qgis.qgis[705]	  if not self.__coordRSGoogle.createFromEpsg(idEpsgRSGoogle):
> 13/07/12 15:20:15	[0x0-0x51051].org.qgis.qgis[705]	Warning: QGraphicsScene::removeItem: cannot remove 0-item
> 13/07/12 15:20:21	[0x0-0x51051].org.qgis.qgis[705]	/Users/joseca_IMac/.qgis//python/plugins/ras/openlayers_plugin.py:167: DeprecationWarning: QgsCoordinateReferenceSystem.createFromEpsg() is deprecated
> 13/07/12 15:20:21	[0x0-0x51051].org.qgis.qgis[705]	  if not self.__coordRSGoogle.createFromEpsg(idEpsgRSGoogle):
> 13/07/12 15:20:40	[0x0-0x51051].org.qgis.qgis[705]	/Users/joseca_IMac/.qgis//python/plugins/xytools/xytools.py:52: DeprecationWarning: QgisInterface.actionCapturePoint() is deprecated
> 13/07/12 15:20:40	[0x0-0x51051].org.qgis.qgis[705]	  "XY tools", self.iface.actionCapturePoint().actionGroup())
> 13/07/12 15:20:42	[0x0-0x51051].org.qgis.qgis[705]	Warning: QGraphicsScene::removeItem: cannot remove 0-item
> 13/07/12 15:20:43	[0x0-0x51051].org.qgis.qgis[705]	/Users/joseca_IMac/.qgis//python/plugins/gmap_overview_plugin/gmap_gui.py:134: RuntimeWarning: divide by zero encountered in divide
> 13/07/12 15:20:43	[0x0-0x51051].org.qgis.qgis[705]	  zoom = np.abs((np.array(zooms) - scale)/scale)
> 13/07/12 15:20:49	[0x0-0x51051].org.qgis.qgis[705]	/Users/joseca_IMac/.qgis//python/plugins/valuetool/valuewidget.py:147: DeprecationWarning: QgsMapRenderer.destinationSrs() is deprecated
> 13/07/12 15:20:49	[0x0-0x51051].org.qgis.qgis[705]	  mapCanvasSrs = self.iface.mapCanvas().mapRenderer().destinationSrs()
> 13/07/12 15:21:01	[0x0-0x51051].org.qgis.qgis[705]	/Users/joseca_IMac/.qgis/python/plugins/imgshowhide/logic/imgshowhidewidget.py:143: DeprecationWarning: QgsMapLayer.getLayerID() is deprecated
> 13/07/12 15:21:01	[0x0-0x51051].org.qgis.qgis[705]	  lst = [[lyr.getLayerID(), lyrCatalog.msg()]]
> 13/07/12 15:21:01	[0x0-0x51051].org.qgis.qgis[705]	/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/osm/OsmFeatureDW.py:185: DeprecationWarning: QgsMapRenderer.destinationSrs() is deprecated
> 13/07/12 15:21:01	[0x0-0x51051].org.qgis.qgis[705]	  self.coordXform = QgsCoordinateTransform(renderer.destinationSrs(), QgsCoordinateReferenceSystem(4326))
> 13/07/12 15:21:02	[0x0-0x51051].org.qgis.qgis[705]	Warning: QMetaObject::connectSlotsByName: No matching signal for on_mLabelIdLineEdit_textChanged(QString)
> 13/07/12 15:21:53	[0x0-0x51051].org.qgis.qgis[705]	Fri Jul 13 15:21:53 torre-a-102.fcien.edu.uy QGIS[705] <Error>: kCGErrorIllegalArgument: CGSOrderWindowList
> 13/07/12 15:21:53	[0x0-0x51051].org.qgis.qgis[705]	Fri Jul 13 15:21:53 torre-a-102.fcien.edu.uy QGIS[705] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
> 13/07/12 15:22:13	[0x0-0x51051].org.qgis.qgis[705]	Warning: Object::disconnect: No such signal QObject::extentChanged()
> Many thanks in advance,
> Jose Carlos Guerrero
> Dr. José Carlos Guerrero
> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio (LDSGAT)
> Instituto de Ecología y Ciencias Ambientales (IECA)
> Facultad de Ciencias
> Universidad de la República
> Montevideo-URUGUAY
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
- Marvin
