[Qgis-user] Atlas Plugin
Vincent Picavet vincent.ml at oslandia.com
Sun Jul 15 06:55:08 PDT 2012
Hello,
The official qgis plugin repository is now at
http://plugins.qgis.org/plugins/plugins.xml
You will find Atlas plugin there.
But I still suggest you to upgrade to now stable version QGIS 1.8, where this
repository is enabled by default.
Vincent
Le vendredi 13 juillet 2012 19:39:21, lt a écrit :
> what should I search for?
> I write ATLAS in the search bar but in no repository I find the atlas plug
> in. I am running Qgis 1.7.3 under winXP can you paste me the repository's
> address to add it manually?
> thank you
> laura
> Il giorno 13/lug/2012, alle ore 19:23, Vincent Picavet ha scritto:
> > Hi,
> > Le vendredi 13 juillet 2012 19:12:36, lt a écrit :
> >> I read in this ML about the Atlas Plugin, but I cannot find it in the
> >> fetch python plug in console. Can you help me? thank you
> > There are now 2 versions, both in the new repository :
> > * stable needs at least qgis 1.6
> > * experimental needs at least qgis 1.9 (current master)
> > If you still run qgis < 1.8 you have to add the new repository manually,
> > but you'd better install ggis 1.8 and have it out of the box.
> > Vincent
