[Qgis-user] shp a GPS
Filipe Silva Dias filipesdias at gmail.com
Sun Jul 15 11:56:12 PDT 2012
Hi
I had that problem but never found the solution
Probably someone on this list can help you, but if all else fails try
DNRGPS, it works smoothly:
http://www.dnr.state.mn.us/mis/gis/DNRGPS/DNRGPS.html
On Sun, Jul 15, 2012 at 7:51 PM, Juan Pablo Virgillito <
jpvirgillito at gmail.com> wrote:
> Hi I'm trying to load a route to GPS Garmin Etrex Legend, allegedly by
> clicking on the shape and keeping as GPX would be solved but I get the
> following error:
> Failed to export vector file.
> Error: failed to create the Name field (OGR error: Field of name 'Name' is not
> supported in GPX schema. Use GPX_USE_EXTENSIONS option to allow creation of
> the <extensions> use element.)
> Thanks Lene
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120715/bad1c010/attachment.html>
