[Qgis-user] Getting landuse information for several circular polygons
Simon Cropper simoncropper at fossworkflowguides.com
Mon Jul 16 16:56:51 PDT 2012
Manuel,
Once you clip the layers, break the multi-part components apart use the
following menu sequence "Vector > Geometry Tools > Multiparts to Single
Parts" -- then they can be summed. You will need to relate you bits back
to your buffer layers however, to match which bit goes in which buffer.
Alternatively, and easier in my mind, you could "Union" your layers.
This creates an exploded layer where each bit has attributes of both
parent layers. You can then delete those elements that do not have a
buffer value. Two steps but less messy.
On 17/07/12 03:22, Manuel Spínola wrote:
> Dear list members,
> I have a landuse layer and another layer with 20 circular polygons
> (buffers) and I want to obtain the amount of each landuse category
> within each circular polygon.  I tried "clip" from Geoprocessing Tools
> but I dont get the information individualized for each circular polygon.
>   Is it possible to get the landuse within each circular polygon in one
> step?
> Best,
> Manuel
> *Manuel Spínola, Ph.D.*
> Instituto Internacional en Conservación y Manejo de Vida Silvestre
> Universidad Nacional
> Apartado 1350-3000
> Heredia
> COSTA RICA
> mspinola at una.ac.cr <mailto:mspinola at una.ac.cr>
> mspinola10 at gmail.com <mailto:mspinola10 at gmail.com>
> Teléfono: (506) 2277-3598
> Fax: (506) 2237-7036
> Personal website: Lobito de río
> <https://sites.google.com/site/lobitoderio/>
> Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
> Qgis-user mailing list
Cheers Simon
    Simon Cropper - Open Content Creator
    Free and Open Source Software Workflow Guides
    Introduction               http://www.fossworkflowguides.com
    GIS Packages           http://www.fossworkflowguides.com/gis
    bash / Python    http://www.fossworkflowguides.com/scripting
