[Qgis-user] Problem with "add postgis layers" in qgis 1.80
Jürgen E. Fischer jef at norbit.de
Thu Jul 19 02:15:51 PDT 2012
Hi Bernhard,
On Thu, 19. Jul 2012 at 11:01:24 +0200, Bernhard Ströbl wrote:
> Therefore QGIS 1.7.4 loads the view with an sql-query e.g.
> "upper(geometrytype("the_geom")) IN ('POLYGON','MULTIPOLYGON')" whereas
> 1.8 does not. So 1.7 only checked 100 features and detected their
> geometry type and made sure that only fitting types are loaded by
> setting an appropriate query.
You checked "use estimated metadata" in 1.7, but apparently not in 1.8.
> Also QGIS 1.7 offered the possibility to already open a schema while
> still detecting. The type said "waiting" for the views in question but
> you could nevertheless load a layer where the geometry type was already
> detected (e.g. because it is registered in geometry_columns).
The detection is now done in a thread, so you can cancel the detection.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
