[Qgis-user] create a tiff multy layer
Eric Goddard egoddard at memphis.edu
Fri Jul 20 06:17:20 PDT 2012
You can accomplish this with gdal. On QGIS 1.8.0, go to the Raster
menu -> Miscellaneous ->Merge. Select all of your input files and
check the layer stack option. The output will be a new tif image with
each of your previously independent images as a band which you can
then assign to the RGB guns by pulling up the layer properties and
clicking the symbology tab.
Eric
On Thu, Jul 19, 2012 at 2:03 PM, Clara Rey Caramés <carames at gmail.com> wrote:
> Hello everybody,
> I am working with multispectral images, but  each band is an independent
> file and I need to create a multifile image.
> Does anybody know how to do it with qgis?
> Thank you!
> Qgis-user mailing list
