[Qgis-user] Selecting polygons on attribute - Trying OGR
Zoltan Szecsei zoltans at geograph.co.za
Tue Jul 24 07:52:02 PDT 2012
On 2012/07/24 16:41, Micha Silver wrote:
> On 07/24/2012 03:10 PM, Zoltan Szecsei wrote:
>> Hi,
>> I have a SHP file of some 1.1m polygons, of which I need to select
>> about half of them, and save them as a separate SHP file.
>> The trouble is when I select either via a Query, or via the TABLE
>> using the select options below, it just falls asleep (100% CPU (ok,
>> 12% as it must be single-threaded)).
>> After 45 minutes or so, I just kick it out and weep.
>> My platform is Win 7 Prof 64 bit (also tried on 32 bit) and using
>> 1.8.0 Lisboa.
>> The selects I have tried are: "sq21code" = "C016*"   and also tried
>> using "IN"
>> Any ideas what I am doing wrong and what I should try next?
> In addition to Andre's correction about the * wildcard, with 1M
> polygons, you probably should move the shapefile into a database (i.e
> spatialite, PostGIS)
That would be a bit sad (in terms of extra steps).
I'm trying with ogr on Linux, but haven't fiddled the correct syntax yet:
zls at gs0:~$ ogr2ogr -where " 21DigitKey LIKE 'C016%' "      zerf
/mnt/geo_lvm0/SGO_cadastral/200909/WC/Erf.shp
ERROR 1: SQL Expression Parsing Error: syntax error
FAILURE: SetAttributeFilter( 21DigitKey LIKE 'C016%' ) failed.
zls at gs0:~$
>> Thanks & regards,
>> Zoltan
> Micha Silver
> GIS Consultant, Arava Development Co.
> http://www.surfaces.co.il
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897  Mobile: +27-83-6004028
Fax: +27-86-6115323     www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120724/e58871bd/attachment.html>
