[Qgis-user] [Qgis-developer] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Etienne Tourigny etourigny.dev at gmail.com
Tue Jul 24 14:32:40 PDT 2012
On Tue, Jul 24, 2012 at 6:22 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Etienne,
> 2012/7/24 Etienne Tourigny <etourigny.dev at gmail.com>:
>> Uploaded 0.4.0 as experimental to the main plugin repos.  Those
>> interested please test and report here or in the valuetool bugtracker.
>> Also any feedback on the resolved bugs (#4905, #4798, #4796) is
>> appreciated.
> I've been out in the field for few days, sorry for coming late to this part of
> the discussion.
> MacOSX: The axes of the graph are drawn, but the following message:
> "There are no statistics in the following rasters:
> TTC1312v2
> Calculate?"
> is displayed over and over no matter the user answers Yes or No.
> The user has to bring the message outside the map area (over the
> Layers list) but then either answering Yes or No Qgis crashes.
> If the user does not answer the message over the map area but brings
> it to the Layer list area and then
> answers either Yes or No, the graphic is displayed and the plugin works.
This seems like a mac problem, Larry reported the same problem with
0.3.6 (without matplotlib) but not with 0.4.0
Sorry but I don't have a mac, so it's hard for me to fix this.
> The matplotlib option is not present.
that's because qwt is not found - so it uses matplotlib. If qwt is not
found, but matplotlib is, then it uses qwt and there is no choice.
> Linux (ubuntu 11:04). Plugin version 0.4.0
> Works fine with both qwt and matplotlib, although much faster with Qwt
> (but speed is not
> a concern here, the graphics are displayed for thinking a while).
I didn't really look into the performance of matplotlib vs. qwt
> Answering Yes or No has the same consequence: the stats are calculated
> and the graph is displayed
I'll look into that - probably related to the bug you experience.
> Linux (ubuntu 10:04): will test tomorrow at the office.
> Many thanks!
> Agus
> Qgis-user mailing list
