[Qgis-user] matplotlib not found on Mac OS
Agustin Lobo alobolistas at gmail.com
Wed Jul 25 01:18:09 PDT 2012
Thanks Noli.
Go to View/Panels and you can activate it there.
Then display a multilayer raster and check both qwt and matplotlib.
If matplotlib is working for you then most likely is that I've done
something wrong in the installation.
Will check this evening and report back.
Agus
2012/7/25 Noli Sicad <nsicad at gmail.com>:
> I am using Mac OS X Lion.
> Installed Value Tool plugin, however, I don't not find the value tool menu.
> Where is it located?
> How to do you check if matplotlib is not find by value tool?
> I sucessfully installed contour plugin which use matplotlib and shapely.
> Noli
> On 7/25/12, Agustin Lobo <alobolistas at gmail.com> wrote:
>> 2012/7/21 William Kyngesburye <woklist at kyngchaos.com>:
>>> On Jul 21, 2012, at 4:14 AM, Agustin Lobo wrote:
>>>> Also, some plugins such as statis complain about not having matplotlib
>>>> despite
>>>> it is installed.
>>> How did you install matplotlib?
>> I installed matplotlib following directions in
>> http://www.kyngchaos.com/software/python
>> and using the dmg provided there.
>> By some reason, while matplotlib is installed, qgis (and the new
>> version on valuetool which can use either qwt or matplotlib) cannot
>> find it.
>> I'm just a casual user of qgis on Mac, so please could any other more
>> experienced Mac user
>> help on testing this?
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
