[Qgis-user] Print Composer: Best Practices
Chris Henrick chrishenrick at gmail.com
Thu Jul 26 09:44:21 PDT 2012
I heard a rumor a while back that someone was developing a plug-in to link
QGIS to Inkscape, anyone know if this is true? I'm a print
cartographer and work
primarily in Adobe Illustrator, a program which is made for vector graphic
design, with the Mapublisher plug-in, which allows you to bring in GIS data
and keep it's attribute and spatial properties (ie you're not limited to
importing SVGs). In my workflow I do use QGIS and GDAL/ogr2ogr to prep my
data before hand. You can then use Illustrator's vastly rich text and
graphic formatting tools to make really beautifully detailed or well
designed simple maps fairly easily. It would be great to see an opensource
equivalent plugin for QGIS to Inkscape.
-Chris
On Wed, Jul 25, 2012 at 11:01 PM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. working with google earth (john raskulinecz)
>    2. Print Composer: Best Practices (Gordon Lane)
>    3. Re: Print Composer: Best Practices (Alex Mandel)
>    4. Re: Print Composer: Best Practices (pcreso at pcreso.com)
>    5. QGIS on Android and Offline Google Maps (Saber Razmjooei)
> Message: 1
> Date: Wed, 25 Jul 2012 14:40:51 -0700
> From: john raskulinecz <jerasku at hotmail.com>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] working with google earth
> Message-ID: <SNT143-W56713FE085B2A9CB3FE663BEC30 at phx.gbl>
> Content-Type: text/plain; charset="iso-8859-1"
> Dear List,
>   I've seen this discussed before and tried to follow the links but still
> do not know how, or if it's
> possible, to load Google earth layers into a Qgis project. Any ideas about
> how to make the two interactive
> would be great.
> Thanks in advance
> John Rask
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120725/f9dd8853/attachment-0001.html
> Message: 2
> Date: Wed, 25 Jul 2012 22:49:15 -0400
> From: Gordon Lane <gwslane at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Print Composer: Best Practices
> Message-ID:
> CAH7AP9t1BV9z0+T8C9RiW2rYJQY0Wd5HN9dV1zvj7qmLEjpwaA at mail.gmail.com>
> Dear List:
> I'll give an overview of a general problem here, then ask for your personal
> Best Practices.
> I use GIS in a professional setting but am not a GIS professional. I
> learned ArcGIS at school and am now trying to transition to the world of
> QGIS. At the moment I typically deal with displaying data, and not so much
> with analysis.
> My major problem is trying to export a good quality map. I typically make
> maps for small-scale areas (50 sq. miles or so, with secondary maps for <1
> sq. mi. details) for decision-making support. These maps aren't fancy, but
> orthos are standard additions to make them accessible to the end-users.
> I have played and tested and cajoled various outputs from Print Composer,
> and still can't find a good workflow for a final product. The legends
> typically are washed-out. The PDF files are waaaay to big (even with res
> set at ~150 dpi), and load in a piecemeal fashion. PNG files are smaller
> than TIFs, but sometimes still too big to email, and don't make legends any
> better. Some of this is because I have an old computer. But not all.
> Additionally, I have not found a way to deal with differences in legend
> colors and shapefile colors when a transparency is set, and have not found
> a way to save anything more than a "template" print composer, which on
> reload is essentially useless.
> So, Best Practices. None of the above have singular solutions. I'm hoping,
> however, that you might be able to give a perspective on the *workflow*
> that *you* use to export maps for consumption. I.e., you religiously use
> one file format vs. another, or have some other settings, or always export
> to another program.
> Looking forward to hear how you work!
> Thanks,
> -Gordon Lane
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120725/72bff182/attachment-0001.html
> Message: 3
> Date: Wed, 25 Jul 2012 21:06:31 -0700
> From: Alex Mandel <tech_dev at wildintellect.com>
> To: Qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Print Composer: Best Practices
> Message-ID: <5010C247.1020708 at wildintellect.com>
> Content-Type: text/plain; charset=ISO-8859-1
> On 07/25/2012 07:49 PM, Gordon Lane wrote:
> > Dear List:
> personal
> > Best Practices.
> much
> > with analysis.
> <1
> but
> any
> found
> hoping,
> export
> > to another program.
> > Thanks,
> > -Gordon Lane
> Here is one possible workflow, I and several others use (and we taught
> in a cartography class a couple of years ago).
> QGIS -> Print Composer -> SVG or PDF (Sometimes with SimpleSVG plugin)
> -> Inkscape
> Sadly SimpleSVG export does not support the New Symbology or New
> Labeling engine. And PDF also has issues with labels not being preserved
> as text which makes them really hard to edit in the next step.
> Final output is usually PDF (Standalone or printing), though depending
> on where it's going Tiff or PNG(web)
> Once you have a PDF or Tiff you can easily eye dropper the fill and then
> bucket fill the legend color boxes to match using GIMP or Inkscape.
> If your page size is big and you want quality your files will be big.
> The best answer then is use a file hosting service and send people links
> to download the PDF.
> The alternate workflow I've been exploring lately is:
> QGIS data prep
> Tilemill styling (Using CSS)
> Mapnik for output or as the base for online tiles.
> Now some examples, everyone started with Arc or QGIS and Finished with
> Inkscape or Illustrator. I'll let you guess which was done with what.
> http://geography.ucdavis.edu/gallery/classes/geo-290-f10-cartography
> Enjoy,
> Alex
> Message: 4
> Date: Wed, 25 Jul 2012 21:44:53 -0700 (PDT)
> From: pcreso at pcreso.com
> Message-ID:
>         <1343277893.57245.YahooMailClassic at web122006.mail.ne1.yahoo.com>
> My preferred print composer is not part of QGIS.
> For Open Source cartography GMT (Generic Mapping Tools) is hard to beat.
> Impeded by an arcane command line interface which suits technophiles... but
> delivers outstanding printed maps. If you have pretty repeatable
> requirements, such as as described by Gordon, it can be worth spending some
> time setting up some template scripts which can be reused as required.
> See (example outputs below the scripts):
> http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1360007.10
> http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1490007.23
> http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1480007.22
> http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1520007.26
> http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1540007.28
> http://gmt.soest.hawaii.edu/gmt/html/GMT_Docs.html#x1-1350007.9
> GMT can create georeferenced bitmaps (with world files) so can generate
> very good imagery for use with QGIS. It can also be used (via OGR & GDAL)
> to compose maps from the same source data viewed in QGIS, so can be used as
> a standalone cartographic tool for poster & scientific quality maps
> alongside QGIS.
> Cheers,
> ?? Brent Wood
> Date: Thursday, July 26, 2012, 4:06 PM
> > Dear List:
> personal
> > Best Practices.
> much
> > with analysis.
> <1
> but
> any
> found
> hoping,
> export
> > to another program.
> > Thanks,
> > -Gordon Lane
> -> Inkscape
> QGIS data prep
> Enjoy,
> Alex
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20120725/63c44bb7/attachment-0001.html
> Message: 5
> Date: Thu, 26 Jul 2012 07:00:54 +0100
> From: Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk>
> Subject: [Qgis-user] QGIS on Android and Offline Google Maps
> Message-ID: <1343282454.2591.11.camel at ioio>
> Content-Type: text/plain; charset="UTF-8"
> Dear list,
> The recent version of Google Maps made it possible to cache maps locally
> to use offline.
> Has anyone had any luck reading them in QGIS? I tried to search around
> but apparently it is not supported in gdal yet.
> Cheers
> Saber
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately
> by e-mail if you have received this e-mail by mistake and delete this
> e-mail from your system. If you are not the intended recipient you are
> notified
> that disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out
> such checks as you feel appropriate.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
> End of Qgis-user Digest, Vol 77, Issue 87
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120726/37bc592f/attachment.html>
