[Qgis-user] options of using neighborhood/moving windows analysis in QGIS
maning sambale emmanuel.sambale at gmail.com
Sun Jul 29 19:47:25 PDT 2012
Dear Richard,
Thanks for the SAGA advice, I'll give it a run.
On Mon, Jul 30, 2012 at 12:19 AM, richard burcher <drownedfrog at gmail.com> wrote:
> AFAIK Raster Calculator can not do moving neighbor analysis with a defined
> kernel.
> If you need a custom kernel (adaptive filter approaches) also look at
> r.mfilter. Note r.mapcalulator can be used but the r.mfilter kernel file is
> a bit easier to work with.
> If you install SAGA Gis, you have several options under the Grid -- Filter
> menu.
> Cheers,
> Richard
> View this message in context: http://osgeo-org.1560.n6.nabble.com/options-of-using-neighborhood-moving-windows-analysis-in-QGIS-tp4991528p4991668.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
