[Qgis-user] startup problem qgis master
Paulo van Breugel p.vanbreugel at gmail.com
Tue Jul 31 07:35:57 PDT 2012
I didn't, but doing so does make it run.
What I do not understand is that I created a config file (qgis_dev.conf)
in /etc/ld.so.conf.d (and run sudo ldconfig afterwards), which I though
should take care of defining the path. I'll check if I did not do
anything wrong there.
Thanks for your help
Paulo
On 07/31/2012 03:51 PM, Tim Sutton wrote:
> Hi
> On Tue, Jul 31, 2012 at 3:05 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> Hi, I used ccmake with CMAKE_INSTALL_PREFIX: /usr/local/qgis_dev, if that is
>> what you mean (I have qgis 1.8 installed in /usr/local/qgis18, if that is of
>> any importance)?
>> I then tried to run it from within the /usr/local/qgis_dev/bin with ./qgis,
>> giving the reported error message.
> Did you do this before running?
> export LD_LIBRARY_PATH=/usr/local/qgis_dev/lib
> /usr/local/qgis_dev/bin/qgis
> Tim
>> Cheers
>> Paulo
>> On Tue, Jul 31, 2012 at 2:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>> Hi
>>> On Tue, Jul 31, 2012 at 2:40 PM, Paulo van Breugel
>>>> I have compiled / build QGIS master branch downloaded from the QGIS
>>>> download
>>>> page (qgis-Quantum-GIS-final-1_8_0-601-gc859799.tar.gz) on Ubuntu 12.04.
>>>> No
>>>> error message during building, but when trying to run qgis, I am getting
>>>> the
>>>> following error message:
>>>> ./qgis: symbol lookup error: ./qgis: undefined symbol:
>>>> _ZN14QgsRasterLayer20CUMULATIVE_CUT_UPPERE
>>> What install prefix did you use?
>>> export LD_LIBRARY_PATH=<install prefix>/lib
>>> <install prefix>/bin/qgis
>>> Regards
>>> Tim
>>>> Any idea how to solve this?
>>>> Thanks
>>>> Paulo
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>>   * QGIS programming and support services
>>>   * Mapserver and PostGIS based hosting plans
>>>   * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120731/292f32f2/attachment.html>
