[Qgis-user] QGIS WEB Client / Qgis Server
Till Adams adams at terrestris.de
Mon Jun 25 08:00:54 PDT 2012
EPSG 900913 is the google-projection, so you probably asked for data in
a region, where nothing is.... ::
The BBOX is min x / y and  max x/y-coordinate in the refering
EPSG-Code-parameter of your getmap-Request. So your BBOX-values should
fit to your data-extent.
There is no place to set the EPSG of the WMS-Server, this is up to the
client using your service - so your WMS-Server might be fine now.
If you open your project properties in qgis, there's a tab called "ows
server" and there you may restrict the used EPSG-codes (or better the
allowed).
That means, that QGIs server will deliver the data in any EPSG you allow
here - if you do nothing here, QGIS will allow ALL known EPSG-codes,
including your 22523.
If you load your WMS in any client, just refer to your data's epsg-code,
so loading the WMS in QGIS-DEsktop, you should say, that the EPSG code
is "22523" - then QGIS will automatically switch the requested EPSG-code
in the getMap request.
For your test-getMap request it's fine if you just change the code
manually but then also fit your BBOX to your data!
Regards, Till
On 25.06.2012 16:48, Kadu Machado wrote:
> Hi....
> I found the problem....
> The qgis-web-client has a URL parameter for SRS=EPSG:900913
> and the URL of the How To install define it like SRS=EPSG:4326
> The SRS of my projects is EPSG:22523
> So, i changed this parameter in the URL of the GetMap and I got a Map :D
> My URL now is:
> http://localhost/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\censo.qgs&LAYERS=censo_2010&*FORMAT=image/png*&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&*SRS=EPSG:22523*&WIDTH=700&HEIGHT=1000&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422
> <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\censo.qgs&LAYERS=censo_2010&FORMAT=image/png&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG:22523&WIDTH=700&HEIGHT=1000&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422>
> So, I have to change FORMAT=image/jpeg to FORMAT=image/png  (to solve
> the erro 500)
> and SRS=EPSG:4326 to SRS=EPSG:22523  (to show the map)
> But, the map is shown in a little space. I think that's because the BBOX
> parameter, that's right?
> Another new problem.... Which js file in the qgis-web-client  must I
> work to change the  SRS parameter?
> In the GlobalOptions.js I changed
> /var overviewLayer = new
> OpenLayers.Layer.WMS("Pixelkarte","/cgi-bin/mapserv?map=/path-to-map/.map",{layers:"pk_kombiniert",*format:"image/jpeg
> "*},  {buffer:0,singleTile:true,transitionEffect:"resize"});/
> To /var overviewLayer = new
> OpenLayers.Layer.WMS("Pixelkarte","/cgi-bin/mapserv?map=/path-to-map/.map",{layers:"pk_kombiniert",*format:"image/png
> *"},  {buffer:0,singleTile:true,transitionEffect:"resize"})/;
> and solve the erro 500 problem... But I didn't find where change the SRS
> parameter....
> On Mon, Jun 25, 2012 at 11:19 AM, Till Adams <adams at terrestris.de
> <mailto:adams at terrestris.de>> wrote:
>     Hi,
>     looks like a problem with your qgis-project.
>     Did you use relative paths to the data?
>     Maybe it's better to start with one layer with a simple symbol for
>     testing whether any map will come out and then go to your "real"
>     project's data.
>     Also do not use complex classification first - this drives you to a
>     step-by-step setup of your webmap, where you test every step and as long
>     as you see the map, everything is all right ...
>     !!! And be aware of browser's cache which could be awful if you do not
>     see any changes in your map.
>     In this case vary the request e.g. by varying the bbox-param a little
>     bit. so that he browser can't just take the same image out of his
>     cache ;-)
>     Have fun,
>     Till
>     On 25.06.2012 16:12, Kadu Machado wrote:
>     > Hi Till,,
>     > thanks for your attention...
>     > I followed your Windows How To install.. Actually, it oriented me to
>     > install the Qgis Server.... After I successful got the
>     GetCapabilities,
>     > I installed the qgis-web-client without try the getMap...
>     > After i've seen your mail, i tried do just like you said... I
>     tried the
>     > getmap before using QGIS-client....
>     > So, I tried this
>     > URL:
>     http://localhost/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/projetos/censo.qgs&BBOX=-36.215710,6.817432,-9.700450,58.551008&WIDTH=500&HEIGHT=1000&LAYERS=censo_2010&FORMAT=image/png
>     <http://localhost/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/projetos/censo.qgs&BBOX=-36.215710,6.817432,-9.700450,58.551008&WIDTH=500&HEIGHT=1000&LAYERS=censo_2010&FORMAT=image/png>
>     <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/projetos/censo.qgs&BBOX=-36.215710,6.817432,-9.700450,58.551008&WIDTH=500&HEIGHT=1000&LAYERS=censo_2010&FORMAT=image/png
>     <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/projetos/censo.qgs&BBOX=-36.215710,6.817432,-9.700450,58.551008&WIDTH=500&HEIGHT=1000&LAYERS=censo_2010&FORMAT=image/png>>
>     > I'm sure that the project name and layers are correct.
>     > This URL gives me no error in apache log or in Console of the
>     > Development tools of Google Chrome... However, gives me no maps
>     either...
>     > I've noticed that the qgis-client was calling this
>     > url:
>     http://localhost/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image/jpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
>     <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300>
>     > If I change the FORMAT=image/jpeg for FORMAT=image/png the error
>     500 is
>     > solved, but the map is not shown....
>     > I'm using the Apache/2.2.14 (Win32) mod_fcgid/2.3.6 configured
>     > Server built: Sep 28 2009 22:41:08
>     > Any other Idea?
>     > Regards,
>     > Kadu
>     > On Mon, Jun 25, 2012 at 9:18 AM, Till Adams <adams at terrestris.de
>     > <mailto:adams at terrestris.de <mailto:adams at terrestris.de>>> wrote:
>     >     Dear Kadu,
>     >     this looks like an installation problem of your qgis-server as
>     it is not
>     >     able to deliver a map on a getmap-request. The labels and so
>     are drawn
>     >     by OpenLayers, the core of the QGIS client.
>     >     It's easier to test the pure qgis-server installation first
>     and try via
>     >     the getmap request, before using QGIS-client as you have less
>     >     dependencies.
>     >     I tried my best for a windows-install howto, look here:
>     http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#Windows
>     >     I would suggest to check this first.
>     >     Regards, Till
>     >     On 25.06.2012 14:12, Kadu Machado wrote:
>     >     > Hi folks....
>     >     > I have a little issue with Qgis WebClient over Windows....
>     >     > When I access the qgis web client, the layers and labels are
>     >     loaded and
>     >     > are showed normally, but the map dont.... After the message
>     >     loading map,
>     >     > the map just dont open. The frame is still blank.
>     >     > I notice that a Internal Error 500 occour:
>     >     >  1. GET
>     http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
>     <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:%5Cprojetos%5Credes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
>     <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:%5Cprojetos%5Credes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300>
>     <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:%5Cprojetos%5Credes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300>>>
>     >     >     500 (Internal Server Error) OpenLayers.js:1000
>     >     >     <http://srv-vibgeo01/maps/libs/openlayers/OpenLayers.js>
>     >     > Anyone has some ideia how to solve this problem???
>     >     > "Quem quer fazer alguma coisa, encontra um meio. Quem não
>     quer fazer
>     >     > nada, encontra uma desculpa."
>     >     > (Roberto Shinyashiki)
>     >     > _______________________________________________
>     >     > Qgis-user mailing list
>     >     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>
>     >     > http://lists.osgeo.org/mailman/listinfo/qgis-user
>     >     --> GO Mobile - jetzt WebGIS auch auf Smartphones <--
>     >           ! Achtung - terrestris hat eine neue Adresse !
>     >     terrestris GmbH & Co. KG
>     >     Puetzchens Chaussee 56
>     >     53227 Bonn
>     >     Germany
>     >     Till Adams
>     >     Geschaeftsfuehrung
>     >     Tel:            +49 (0)228 / 962 899-52
>     <tel:%2B49%20%280%29228%20%2F%20962%20899-52>
>     >     Mobile: +49 (0)151 / 25394429
>     <tel:%2B49%20%280%29151%20%2F%2025394429>
>     >     Fax:            +49 (0)228 / 962 899-57
>     <tel:%2B49%20%280%29228%20%2F%20962%20899-57>
>     >     http://www.terrestris.de
>     >     Amtsgericht Bonn, HRA 6835
>     >     Komplementaerin:
>     >     terrestris Verwaltungs GmbH
>     >     vertreten durch:
>     >     Hinrich Paulsen, Till Adams
>     > "Quem quer fazer alguma coisa, encontra um meio. Quem não quer fazer
>     53227 Bonn
>     Germany
>     Till Adams
>     Geschaeftsfuehrung
>     Mobile: +49 (0)151 / 25394429 <tel:%2B49%20%280%29151%20%2F%2025394429>
>     Komplementaerin:
>     vertreten durch:
53227 Bonn
Germany
Till Adams
Geschaeftsfuehrung
Komplementaerin:
vertreten durch:
