[Qgis-user] Export map to graphics program
Alex Mandel tech_dev at wildintellect.com
Tue Mar 6 09:29:23 PST 2012
Thanks for the additional information, I'll try to pass it on to the
developer of the plugin.
Was it working in 1.7.3?
Thanks,
Alex
On 03/06/2012 09:24 AM, Gerhardus Geldenhuis wrote:
> Hi
> Confirming that I am using SimpleSVG
> Some more details here is the error message when it fails:
> http://pastebin.com/uPbVR08h.
> When it was still working it would not for example show my spatialite
> layers data. With the current version of my map it simply does not work. I
> have restarted QGIS and restarted my laptop but to no avail. I am using
> Ubuntu 11.04 and QGIS 1.7.4
> My map currently has 6 layers that is visible and they are vector and
> spatialite layers.
> Regards
> On 6 March 2012 17:18, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> On 03/06/2012 03:15 AM, Gerhardus Geldenhuis wrote:
>>> Hi
>>> I have tried to use the python plugin to export my map as a svg. When it
>>> worked it was selective about which layers it exported and at the moment
>> it
>>> crashes. I was wondering if there is another way of exporting an image or
>>> vector graphic of my map. I want to add final touches to my paper copy
>> map
>>> in Illustrator and am at the moment considering doing a number of print
>>> screens and stitching it together.
>>> Regards
>> In addition to the SimpleSVG plugin (I assume thats the one you are
>> trying to use), you can save a pdf or svg from the map composer it just
>> tends to come out with some extra stuff.
>> Could you please post more about the error you get? Do you get a message
>> or the output just isn't what you expect? How many layers, what type?
>> Does it fail on even simple exports or just complex ones?
>> Thanks,
>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
