[Qgis-user] GRASS 6.4.2 GUI broken in OS X Lion
William Kyngesburye woklist at kyngchaos.com
Sun Mar 11 08:29:48 PDT 2012
I've been assuming you were compiling QGIS from source - is this correct?  Or are you using my last dev build?
This WILL have problems with the latest GRASS because it was built for GRASS 6.4.1.
I keep forgetting to make a new dev build (it's bugging me also because it's the default QGIS when I double-click a shapefile).
On Mar 9, 2012, at 10:13 PM, Sergio Zárate wrote:
> Thanks for answers.
> Indeed, the problem with GRASS gui was due to wxpython. I was able to start gui using tcltk and succesfully set it for next run, which works fine (>g.gui tcltk; g.gisenv set="GRASS_GUI=tcltk", respectively.
> However, before the above was made, trashing GRASS reestablished function of all versions of Qgis, which would crash at startup. But, with GRASS installed (and working alone) Qgis "master" starts, but crashes as soon as GRASS plugin is enabled (and also when asking to verify version ¿?). That although being reinstalled and .plist files being discarded.
> Anybody would please suggest what to do for Qgis-GRASS to work again?
> Dr. Sergio Zárate Pedroche
> José María Arroyo 228
> Col. 22 de octubre
> Morelia, Michoacán
> C.P. 58341
> México
> ________________________
> Teléfono: (443) 352-5307
> Celular: (443)  438-6212
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable.  There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
