[Qgis-user] Andreas, windows 64 bit
Andreas Neumann a.neumann at carto.net
Mon Mar 12 22:50:20 PDT 2012
Hi John,
No - this should not be a problem. I successfully run QGIS 32bit on
64bit Windows 7. But you cannot use more than the 2-3 GB RAM that are
possible in 32bit Windows application.
The fact that QGIS does not run on your 64bit Windows 7 is a different
problem.
I am afraid I probably can't help much than advising to remove QGIS and
reinstall. You may also try to use the OSGeo4W installer which allows
you to install different QGIS versions in parallel. I usually use QGIS
trunk (developer version, 1.9.x) from OSGeo4W and QGIS 1.7x (stable
version).
Hope this helps,
Andreas
On 03/12/2012 09:49 PM, john raskulinecz wrote:
> Andreas, hello, and thanks for the info. That may explain why my QGIS Wroclaw version quit working after I upgraded to win 7 64 bit on my Acer laptop.I've been going around in circles
> trying to find and reinstall  the missing dll files that the error message keeps telling me about.
> Thanks again,
>  J.R.
> Qgis-user mailing list
