[Qgis-user] Re: Count Points in Polygon
LALIT KUMAR lalit.jss at gmail.com
Mon Mar 12 23:51:11 PDT 2012
Thanks a lot. It worked.
On Tue, Mar 13, 2012 at 1:23 AM, Goyo [via OSGeo.org] <
ml-node+s1560n4571415h41 at n6.nabble.com> wrote:
> El día 12 de marzo de 2012 20:33, LALIT KUMAR <[hidden email]<http://user/SendEmail.jtp?type=node&node=4571415&i=0>>
> escribió:
> > Hi,
> > I am new to GIS , need soome help.
> > I am having a polygon shape file received from an organization. It has
> an
> > User defined CRS
> > +proj=lcc +lat_1=16.625 +lat_2=21.125 +lat_0=18.8801575 +lon_0=76.75
> > +x_0=1000000 +y_0=1000000 +ellps=WGS84 +datum=WGS84 +units=m +no_def
> > I am having a set of points with only their latitude and longitudes in
> CSV.
> > I am able to import this in QGIS and save it as shape flle an sets its
> CRS
> > as  UTM ZONE 43N.
> > By enabling on the fly and  I am able to see these points are located in
> the
> > polygons.
> > I need to count how many points are there in each polygon. The plugin
> for
> > this say different CRS.
> > When I set the User defined CRS for point shape file , the polygon and
> > points are not overlayed .
> > What I suppsed to do
> You must reproject one of the layers, not "on the fly" but "on the
> disk". Right click on a layer in the legend, choose "save as" and
> select the destination CRS to match the other layer, then load the new
> layer in QGIS.
> Goyo
> Qgis-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4571415&i=1>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/Count-Points-in-Polygon-tp4571341p4571415.html
>  To unsubscribe from Count Points in Polygon, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4571341&code=bGFsaXQuanNzQGdtYWlsLmNvbXw0NTcxMzQxfC0xNDYyNzk1ODI3>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/Count-Points-in-Polygon-tp4571341p4573034.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120312/0b7cf20d/attachment.html>
