[Qgis-user] mmqgis on OSX
William Kyngesburye woklist at kyngchaos.com
Tue Mar 13 20:17:40 PDT 2012
I think all those warnings are already there when QGIS starts.  Nothing new shows up for me when I try to use one of the mmqgis functions.  And same as you - nothing happens.
One odd thing I see in the python files for the plugin is an empty "mmqgis_dialog.py".
On Mar 13, 2012, at 8:57 PM, David Fawcett wrote:
> I am running QGIS 1.9.90-Alpha  revison e13e45f  on OSX Snow Leopard
> from William's installers at kyngchaos.com.
> QGIS works great and seems to run faster than past versions.  I am
> running into an issue with the mmqgis pluggin.  Maybe this dev build
> is just not fresh enough.
> I can successfully find and install the plugin.  When I select any of
> the options from the pluggins>mmqgis menu, no dialogs appear.  I am
> guessing that it is an issue with Qt.
> Here is what I see in the console:
> 3/13/12 8:23:08.565 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
> loading of qgis translation failed
> [/Applications/QGIS-1.9.app/Contents/MacOS/../Resources/i18n//qgis_en_US]
> 3/13/12 8:23:08.566 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
> loading of qt translation failed
> [/Applications/QGIS-1.9.app/Contents/translations/qt_en_US]
> 3/13/12 8:23:14.069 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
> QFSFileEngine::open: No file name specified
> 3/13/12 8:23:22.256 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
> QHttp: empty path requested is invalid -- using '/'
> 3/13/12 8:27:12.413 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
> Object::connect: No such signal QComboBox::textChanged( const QString&
> Object::connect:  (sender name:   'cmbTheme')
> Object::connect:  (receiver name: 'QgsOptionsBase')
> Object::connect:  (sender name:   'cmbIconSize')
> 3/13/12 8:27:12.414 PM [0x0-0x15015].org.qgis.qgis-dev: Warning:
> If anyone thinks that there is a clear issue that warrants a ticket,
> let me know and I will file one.
> Thanks,
> David.
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
