[Qgis-user] A problem (shift of 50 m) with some lcc projections and "on the fly" reprojection in QGIS 1.7.4 for Debian Squeeze amd64 bits
Giovanni Manghi
giovanni.manghi at faunalia.pt
Thu Mar 29 00:17:02 PDT 2012
Hi, I do not have the time now tor read carefully allt he mail, but ti
seems to me something similar to this
http://hub.qgis.org/issues/5142
that happens only in Lunux and qgis-master.
cheers
-- Giovanni --
On Thu, 2012-03-29 at 04:09 +0200, blavet wrote:
> Dear developpers and users of QGIS
> First of all i want to thank the developers of Qgis for this excellent
> software that i follow since the version 0.9 Now the number of my
> colleagues using QGIS is increasing. Itr is very usefull for our
> experimental work in the field (with soil mapping and localisation and
> agronomical trials ) and we also start now to use Qgis with a
> differential gps, in order to localize very precisely some new
> samplings and field trials and indicate them in previous maps.
> Therefore for our work, the QGIS version 1.7.4 with "on the fly"
> projection of vectors and rasters is very interesting.
> Unfortunately I have a now a quite tricky problem with Qgis 1.7.4 for
> Debian Squeeze (obtained from the Qgis repository
> http://qgis.org/debian/) . And, following my tests this problem does
> not occur with some other OS and QGIS 1.7.4 (namely Windows and
> Ubuntu)
> In Debian Squeeze with the version 1.7.4 of QGIS, whatever i do, when
> i try"on the fly projection" (of course with on "the fly reprojection"
> activated ) i have systematically a shift of about 50 meters between
> my layers in "lambert II etendu" and the layers two other projections
> (Lambert 93 and RGFCC43) ....
> I give some details of my trials in the Annex below
> So .. this is a bit a headache for me … i sincerely think that the
> problem comes from the Debian squeeze version .. probably my
> configuration, but may be a more general problem with Debian squeeze
> and QGIS 1.7.4
> I would want to use QGIS 1.7.4 with Debian stable (Squeeze) and to
> have good "on the fly projections" and good reprojections for my lcc
> layers … but for the moment is seems difficult …
> So thank you in advance if you could give me some help
> Kind regards
> ANNEX about the tests that i did
> I first tried to verify that i did not made mistake with my layers …
> some of my layers in lambert II etendu came from reprojections of
> "old" layers in lambert zone III and i wondererd if i made good
> reprojections .
> But such a mistake would not be logical because these reprojected
> layers are very well overlaid in QGIS with orthophotos in lambert II
> etendu, and also i can find very precisely the localisation of my
> observations in geospatial websites if i convert the localisation
> provided by my layers in lambert II etendu in geographical
> coordinates.
> i also tried in Debian squeeze to find a way to obtain a good
> overlaying several combinations, Then i also observed that when i make
> a real reprojection (not on the fly) with my vector layers in RGFCC43
> to lambert II etendu (with softwares such as IGNMAP) all the layers
> including the layers in CC43 were perfecty overlaid in a project in
> lambert II etendu !! This indicated to me that my layers should be
> definitively ok and should overlay. ..
> So i finally was convinced that all my layers were correct and should
> overlay perfecly !! .. and that this problem could come from somewhere
> else.
> Then, "just by chance" i had to try QGIS 1.7.4 for Windows and i tried
> with exactly the same layers that i have : several layers in lambert
> II étendu, one vector (dgps datat) in CC43 and two rasters in lambert
> 93 (just a copy from the files udes in Debian, of course same
> projections , and same parameters in Qgis with "on the fly
> reprojection activated) ) And .. Bingo !! this shift of 50 m
> disappeared immediately with Qgis 1.7.4 for Windows.
> Well, i then tested QGIS 1.7.4 for Gnu/Linux Ubuntu distribution LTS
> Lucid Lynx and second Bingo !! . In this two cases all my layers were
> immediately and perfectly overlaid together !!.
> So .... this 50 m shift seems to be connected with the Debian version
> … But i still want to use Debian, that i use daily !! (:-)
> … Thereafter i tried to compare the versions of QGIS 1.7.4 in the
> three OS
> As indicated in the message "about" i have this specifications
> Qgis 1.7.4 for Debian squeeze is compiled from the version "exported"
> of the code
> and is using :
> GDAL/OGR version 1.6.3
> Version de QWT : 5.2.0.
> is compiled with Qt 4.6.3 and run with Qt 4.6.3
> Qgis 1.74 for lucid Lynx LTD (which does not have also this 50 m
> shift) is compiled from the version "exported" of the code
> and is using :
> GDAL/OGR version 1.8 .0
> is compiled with Qt 4.6.2 and run with Qt 4.6.2
> Qgis 1.7.4 for windows (which does not have this 50 m shift") is
> compiled from version 411aff6 of the code
> and is using :
> GDAL/OGR version 1.8.1
> Version de QWT : 5.2.1.
> is compiled with Qt 4.7.1 and run with Qt 4.7.1
> From this comparison I supposed that my problem could be linked with
> the version of GDAL/OGR which is a bit older in the Debian Squeeze.
> Then i uninstalled Qgis 1.7.4 in Debian (with purge), also in
> uninstalled all the libgdal and I reinstalled QGIS 1.7.4 after having
> added the gfoss repository to obtain libgdal1-1.7.0. Unfortunately,
> even with libgdal1-1.7.0 installed in Debian, QGIS 1.7.4 still says
> that it is using GDAL/OGR 1.6.3.. Also if i try to just uninstall
> libgdal1-1.6.0 (which is named version 1.6.3-4+b1 (stable)) the
> synaptic package manager says that it would uninstall Qgis....
> By the way i also observed a strange behaviour in the metadata for
> the Debian version
> (i'm not sure that this is connected with the previous one, but it
> would not be impossible)
> In my three Operating systems, the proj4 definition of the projection
> Lambert II etendu IGNF:LAMBE ID : 10090 indicates the use of a nadgrid
> ntf_rgf93 like this :
> +proj=lcc +nadgrids=ntf_r93.gsb,null +a=6378249.2000
> +rf=293.4660210000000 +pm=2.337229167 +lat_0=46.800000000
> +lon_0=0.000000000 +k_0=0.99987742 +lat_1=46.800000000 +x_0=600000.000
> +y_0=2200000.000 +units=m +no_defs
> However in Debian Squeeze version of Qgis 1.7.4 when i "right click"
> on a layer in "Lambert II etendu" to obtain the properties and the
> medatata about the SCR the +nadgrids=ntf_r93.gsb,null simply
> disappears in the medata , and i just obtain this :
> +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000
> +y_0=2200000 +a=6378249.2 +b=6356514.999978254 +pm=2.337229167
> +units=m +no_defs
> (by the way i think that there is no problem with the b instead of rf,
> it is ok, as b = a*(1 - 1/rf)) The only problem seems to be with
> +nadgrids=ntf_r93.gsb,null which have disappeared in the metadata
> provided
> Moreover, in the other OS (Ubuntu Lucid lynx and Windows) i still have
> the +nadgrids=ntf_r93.gsb,null in the metadata. I obtain this by a
> right click on the layer and going the metadatya :
> +nadgrids=ntf_r93.gsb,null +pm=2.337229167 +units=m +no_defs
> (by the way I also verified that i have the same file ntf_rg83.gsb in
> usr/share/proj in Ubuntu and in Debian versions .. it is ok i have the
> same file (same size, same md5sum)...
> finally for the proj, proj-bin and proj-data package i have 4.7.0-1
> in, Debian squeeze and 4.7.0-2 in Ubuntu Lucid Lynx (i'm note sure
> also if this is important or not)
> _______________________________________________________________________________________
> Didier Blavet
> Institut de Recherche pour le Développement - IRD (http://www.ird.fr)
> UMR Eco&Sols - Ecologie Fonctionnelle & Biogéochimie des Sols &
> Agroécosystèmes
> (Montpellier SupAgro-CIRAD-INRA-IRD)
> (http://www.montpellier.inra.fr/ecosols)
> Bâtiment 12, 2 place Viala, F-34060 Montpellier Cedex 2 , France
> Tel bureau : +33 (0)4 99 61 21 33
> Secrétariat : +33 (0)4 99 61 21 01 / Fax : +33 (0)4 99 61 21 19
> Courriel : didier.blavet at ird.fr
> Qgis-user mailing list
