[Qgis-user] Re: ecw problems
Pietro Rossin pietro.rossin at gmail.com
Thu Mar 29 02:02:15 PDT 2012
Hi Ramon
I'm using OSgeo installer and It installed gdal 1.9.
I have gdal_ECW_JP2ECW.dll in bin/gdalplugins/1.9.
QGis.bat (in "%OSGEO4W_ROOT%"\bin\) is like this:
@echo off
SET OSGEO4W_ROOT=d:\OSGeo4W
call "%OSGEO4W_ROOT%"\bin\o4w_env.bat
call "%OSGEO4W_ROOT%"\apps\grass\grass-6.4.2\etc\env.bat
@echo off
path %PATH%;%OSGEO4W_ROOT%\apps\qgis\bin;%OSGEO4W_ROOT%\apps\grass\grass-6.4.2\lib
start "Quantum GIS" /B "%OSGEO4W_ROOT%"\apps\qgis\bin\qgis.exe %*
So it hasn't the gdal plugin setted, should I write it under SET OSGEO4W_ROOT?
Thankyou
Pietro
2012/3/29 Ramon AndiƱach [via OSGeo.org]
<ml-node+s1560n4667123h58 at n6.nabble.com>:
> That's the version where my ecw started behaving completely properly again,
> although I had it running in -4.
> A couple of things to check which might help. (or might not, I've been wrong
> a lot this week!)
> You're using the OSGeo installer right?
> It should have kicked you along to GDAL 1.9. If it hasn't there's some other
> bigger problem.
> Does your qgis.bat have the GDAL plugins path defined? [1],[2]
> It will have been over-written, and might have been lost.
> Do you have gdal_ECW_JP2ECW.dll in bin/gdalplugins/1.9?
> If not, make sure that the ECW SDK dlls are where your computer can find
> them (in the search PATH somewhere) and try reinstalling the gdal-ecw
> package.
> -ramon.
> [1] Something like : SET GDAL_DRIVER_PATH=%OSGEO4W_ROOT%\bin\gdalplugins\1.9
> [2] this used to be in the .bat files, could it be included again?
> On 29/03/2012, at 15:58, Pietro Rossin <[hidden email]> wrote:
>> Hello
>> Today I installed the 1.7.4.5 Qgis update, which still has ecw problems..
>> Shall I open a ticket for this issue?
>> Thankyou
>> Pietro
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/ecw-problems-tp4126237p4667038.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/ecw-problems-tp4126237p4667123.html
> To unsubscribe from ecw problems, click here.
> NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/ecw-problems-tp4126237p4667183.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120329/73fa28b0/attachment.html>
