[Qgis-user] SEXTANTE for QGIS has been released
Gary Sherman gsherman at geoapt.com
Sat Mar 31 10:39:41 PDT 2012
On Mar 31, 2012, at 9:35 AM, Carlos Grohmann wrote:
> Hi, I couldn't find the sextant plugin in qgis 1.7 on mac os x. is it on http://mapserver.sk/~wonder/qgis/plugins-sandbox.xml? this repo is giving connection errors.
> best
It is in the new plugin repository (http://plugins.qgis.org/plugins/plugins.xml). You must have enabled viewing of experimental plugins in the Options tab of the plugin installer in order to see it.
> Carlos
> Prof. Carlos Henrique Grohmann
> Institute of Geosciences - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> ________________
> Can’t stop the signal.
> Sent with Sparrow
> On Friday, 30 March 2012 at 18:19, Victor Olaya wrote:
>>> One remark / request on concerning GRASS; as the GRASS algorithms are
>>> already available through the GRASS toolbox, the main thing for me would be
>>> to enable the use of GRASS raster and vector layers in all the SAGA (and
>>> other) modules. I assume this will be part of the working version you
>>> mention?
>> Well, the idea is just the opposite: to use any raster or vector layer
>> in GRASS, directly from QGIS. "Any" in this context means any "normal"
>> file-based layer. What you propose is just the opposite: to use GRASS
>> layers in other apps. This is something I plan to work on later. As I
>> mentioned in the release note, now SEXTANTE handles those "normal"
>> layers, but not others like layers from remote services, from DB
>> connections or "special" layers like GRASS ones. I hope to give
>> support for all that as well, so any layer than can be loaded into
>> QGIS can be passed to an external application transparently, with
>> SEXTANTE doing the necessary work of conversion or whatever is needed.
>> However, I will wait until this first version works fine before
>> starting that.
>> Regards
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
-gary
Gary Sherman
GeoApt LLC
  http://geoapt.com
Founder, Quantum GIS
Chair, QGIS PSC
Book:
  http://geospatialdesktop.com
"We work virtually everywhere"
