AW: [Qgis-user] Labeling area
Starke Holger, Mag.
Starke at hagel.at
Tue Mar 6 02:10:35 EST 2012
Hello,
I´m using QGIS 1.6 on several tablets and I didn´t found any "expression-based-labeling" in 1.7.4 also. Where can I find this feature?
Thanks!
Holger
Von: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Gesendet: Montag, 05. März 2012 10:38
An: Starke Holger, Mag.
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Labeling area
Sure if you running the latest dev version of QGIS you can use expression based labelling http://woostuff.wordpress.com/2011/10/27/expression-based-labeling/
- Nathan
On Mon, Mar 5, 2012 at 7:11 PM, Starke Holger, Mag. <Starke at hagel.at<mailto:Starke at hagel.at>> wrote:
Hello,
I would like to digitize polygons and label them with their area, but it isn´t possible to select the area of a polygon as the label-field. I could open the Attribute Table and add a new column and calculate the area, but it should be displayed immediately after finishing digitizing, ist this possible?
Holger
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/fb5328aa/attachment.html
