[Qgis-user] GPS-Measure
Ramon Andiñach
custard at westnet.com.au
Tue Mar 6 04:26:47 EST 2012
On 06/03/2012, at 15:14 , Starke Holger, Mag. wrote:
> Hello,
> I´m searching fort a possibility to measure areas using Live-GPS-Tracked vertices. After adding the feature the Area should be displayed and the label should be the measured area. Is it possible to combine the GPS-Tracking Tool with the area measuring tool?
> Holger
I'm not sure I understand correctly. It sounds like you're trying to measure the area of a feature that all GIS programmes will understand as a line. Is that right?
-ramon.
