[Qgis-user] map does not disply right in composer
Jake Maier j.m at jmforestry.com
Fri Mar 9 17:57:51 EST 2012
Thank you very much for the bing map link, Giovanni.
Would you also have a link for topo maps?
Thanks in advance
Jake
-----Original Message-----
From: Giovanni Manghi [mailto:giovanni.manghi at faunalia.pt]
Sent: Friday, March 09, 2012 3:43 PM
To: Jake Maier
Cc: Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] map does not disply right in composer
On Fri, 2012-03-09 at 12:14 -0500, Jake Maier wrote:
> Now that the different layers all display properly, the shp layer is nearly a km to the east in the composer.
> The layer displays right in the map but not in the composer. How can I fix this?
The layers from the OL plugin are not "supported" in the composer. You may want to use this virtual earth wms server
http://geoposer.com:443/server/services/ve.xml
and it will work just fine also in the composer.
-- Giovanni --
