[Qgis-user] Transferiing a project from MapInfor to
QGIS....Please help.....
naomi jackson
naomijackson_fj at yahoo.com
Sun Mar 18 19:59:48 EDT 2012
Hi Andreas,
* if possible use a newer QGIS version like QGIS 1.7.x - there is a lot
of activity in QGIS development and it usually helps to stay with the
current stable version. One day you may even want to try OSGeo4W and the trunk version ;-)
Thanksfor the recommendations i have done so and seems to be working great.
Why do you want to open layers with Python?
After reading online Manuals i believed just as MapInfor has MapBasic, QGIS uses Python to customize menus.
Is it not enough to just
load a QGIS project file? Is there a specific reason why you want to
load the layer with Python? It is certainly possible, but there may be
simpler options.
This project will be launched on PC's for certain departments and they do not work with QGIS(they need it for display only) and most of the time they require a automated program where they do not need to learn steps of opening up projects....
simpler options.
Nice to know that it is possible,I would like to know about the simpler versions.
The other requirement: why do you want a separate menu for layers if
there is a layer tree already where you can right-click and zoom to the
layer extent?
Like I have mentioned our staff are more comfortable with an automated system as how they've seen it in Mapinfor.
What do you gain if you have a separate tree in the menu if you already have a layer tree in QGIS?
a click and all is done.
I appreciate your suggestions and hope to get positive responses...
Is it possible to automatically update the QGIS database when we make changes in Access table??or it has to be done manually every time we update the Access table(.mbd)
Regards
Naomi
To: qgis-user at lists.osgeo.org
Sent: Friday, February 10, 2012 7:31 PM
Subject: Re: [Qgis-user] Transferiing a project from MapInfor to QGIS....Please help.....
Hi Naomi,
I have a few recommendations:
* if possible use a newer QGIS version like QGIS 1.7.x - there is a lot of activity in QGIS development and it usually helps to stay with the current stable version. One day you may even want to try OSGeo4W and the trunk version ;-)
* Why do you want to open layers with Python? Is it not enough to just load a QGIS project file? Is there a specific reason why you want to load the layer with Python? It is certainly possible, but there may be simpler options.
* The other requirement: why do you want a separate menu for layers if there is a layer tree already where you can right-click and zoom to the layer extent? If you insist on such functionality: there is a plugin called "Layers menu from project".
Again: your requirement should be possible to fulfill with python - but I fail to understand the requirement properly? What do you gain if you have a separate tree in the menu if you already have a layer tree in QGIS? Is it worth the effort developing such functionality?
Andreas
On Thu, 9 Feb 2012 18:38:30 -0800 (PST), naomi jackson wrote:
> Hi I am new to Quantum GIS,
> The organization i work for wishes to introduce QGIS to the Pacific
> Island Countries(the fact that is an Open source).
> i would really appreciate your help/assistance.
> The project that i am working on is to migrate a Project that i have
> completed in MapInfo 10.0 using Map Basic 10.0 into QGIS.
> "Customised MapInfo Display Of Land Cover Of The Low Lying islands"
> I wish to display the same in QGIS.
> My PC has :
> · Windows XP(and so do the other users in the department to which i
> will need to install QGIS in their systems when i get it working)
> · Python 2.7
> · QGIS 1.6.0
> Is it possible
> * Automatically open a layer using python “considering Windows
> XP”(I see a lot of examples on linux and Unix)…If so can anyone
> please guide me thru some codes or sites for more clarification.
> * Write a program to create a dropdown menu in QGIS to select layers
> and it automatically zooms to the layer selected rather than using the
> layer control to select manually.(WINDOWS XP)
> I have a whole lot of questions I will begin with these two…..
> Can anyuone help me with python codes that will do the two points
> above...if possible.
> Thanks
> Naomi
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org [1]
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team [2]
> Links:
> [1] mailto:Qgis-community-team at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120318/86a5a685/attachment-0001.html
