[Qgis-user] compiling QGIS version1.9.90-Alpha with GRASS 7.0
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Mar 20 16:40:11 EDT 2012
I have compiled QIGS 1.9 successfully when building with GRASS 6.4 (on
Ubuntu 11.10). However, when I try to build it with GRASS 7.0, I am
running into problems.
In ccmake, I include the following when building with GRASS 6.4 (grass
was build in usr/local/grass6.4.current):
GRASS_INCLUDE_DIR
/usr/local/grass6.4.current/grass-6.4.2svn/include
GRASS_PREFIX /usr/local/grass6.4.current/grass-6.4.2svn
LIB_PATH in
/usr/local/grass6.4.current/grass-6.4.2svn/lib/libgrass_gproj.so
GRASS 7.0 is build in usr/local/grass7.current, thus used the following
in the ccmake:
GRASS_INCLUDE_DIR
/usr/local/grass7.current/grass-7.0.svn/include
GRASS_PREFIX /usr/local/grass7.current/grass-7.0.svn
LIB_PATH /usr/local/grass7.current/grass-7.0.svn/lib
However, when running configure, it apparently cannot find the lib_path,
even though I am sure the path is correct (the field for LIB_PATH is put
to LIB_PATH_NOT_FOUND).
I can still continue with make and make install and QGIS installs and
runs fine, but without GRASS toolbox.
Any help would be appreciated.
Paulo
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120320/f60b87e3/attachment.html
