[Qgis-user] Problem with interpolation plugin
Zara Teixeira
zarafani at gmail.com
Fri Mar 23 12:01:37 EDT 2012
It is in fact the 20790, and I had tried that too.
But the problem remains if I convert it to another CRS.
thanks anyway.
On Fri, Mar 23, 2012 at 3:48 PM, ALT SHN <i.geografica at alt-shn.org> wrote:
> It seems to be a CRS problem.
> First you have to be sure what EPSG code is equivalent to ESRI 102164 (I
> think it's the 20790)
> Before converting to 3763, make sure the layer assumes the correct EPSG
> code as CRS. Go to Properties --> General and then declare 20790 as the
> correct EPSG, Then Save it as 3763.
> Hope it helps
> 2012/3/23 Zara Teixeira <zarafani at gmail.com>
>> Hi,
>> I have this shapefile with points in ESRI: 102164<http://spatialreference.org/ref/esri/102164/>
>> Because all my work is in EPSG 3763, I changed the CRS to this one.
>> The problem is that everytime I try to create a TIN with the
>> interpolation plugin, both QGIS 1.9.9 and 1.7.4 crash. I have them
>> installed in Windows 7.
>> This doesn't happen with the original shapefile, or even if I use the IDW
>> algorithm, but happens if I transform the shapefile to any other CRS.
>> P.S. I would prefer to change the CRS before I interpolate.
>> Any idea why?
>> Thanks in advance.
>> Zara
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Associação Leonel Trindade
> SOCIEDADE DE HISTÓRIA NATURAL
> Apartado 25 2564-909 Torres Vedras Portugal
> Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
> Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
> do Ameal 2565-641 Ramalhal
> http://alt-shn.blogspot.com
> www.alt-shn.org
URL: http://lists.osgeo.org/pipermail/qgis-user/attachments/20120323/b38459af/attachment.html
