[Qgis-user] 1.9 alfa
Percy Langa percylanga at gmail.com
Thu Nov 1 07:36:53 PDT 2012
On 2012/11/01 04:00 PM, Sebastiano Lora wrote:
> Hello, one short question, I updated the daily QGIS alfa (1.9.02 on
> win7 64bit) and I have a problem with the shapefiles: when I open the
> attribute table no values are displayed, even if the polygon are
> correctly displayed and the connection with the .dbf works (I can make
> query or change the visualisation based on the categories). Anybody
> has the same problem?
Same here. Latest qgis-dev on Win 7 64bit.
My workaround is to reload the .shp file (remove & add). Luckily, this
happened to one or two .shp files (polygons). So, it not a huge issue.
Cheers,
Percy
